Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-20-2005, 10:25 PM
Ramblin Fever Ramblin Fever is offline
Need input on a few quirks
on the newly acquired truck - 95.5 with 99K 3.2L V6 4x4 automatic
Muffler - underside is rusty and crumbling in a few spots, beginning, I believe to hear the famous sound of a muffler hole.
Can I put this off for a time without a problem - emissions was done 2 weeks ago, passed without a problem.
Temperature gauge - on the 97 3.2L V6 it stays just a tad to the cool side of square in the middle. On the 95.5, it's only a 1/4 toward the middle, hugs close to the "C", and never gets to the middle, even after running the air-conditioning.
Is this norm for that year?
Transmission shifter - on the floor it registers that it's in "D"; on the dash it registers everything but "D". Though it shifts through the gears, when driving, just fine.
Is this a shifter linkage issue, or a range mode sensor? Transmission is fine in all gears.
Limited Slip - was this offered on this year? And how can I tell if I have it?
ABS - how would I know if I have 4-wheel ABS or not?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 09-30-2005, 12:01 PM
php php is offline
Re: Need input on a few quirks
Verbatim from my Chilton's manual
"Rear axle ratio, differential type, manufacturer, and build date information are stamped on the right axle tube on the front side."
Don't know if it will help or not
1993 Rodeo, V6, 3.2L,
4x4, 5 speed
130,000 miles
Chicago, Illinois
Old 09-30-2005, 12:15 PM
php php is offline
Again according to my manual
4x4's with rear wheel only ABS will have a speed sensor mounted on top of the differential.
4x4's with four wheel ABS will have speed sensors at each wheel
4x4, 5 speed
130,000 miles
Chicago, Illinois
Old 09-30-2005, 12:31 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Look on the driver's side of the firewall and you should see a sticker. At the bottom there will be a list of options codes. You should see G80 if it has LSD.
On the top of the instrument cluster, by the turn signal arrows, there will be an "ABS" idiot light for 4 Wheel ABS or one that says "RrABS" for Rear Wheel ABS.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 09-30-2005, 06:44 PM
Thanks guys, I appreciate the responses.
Unfortunately I only had the luxury of owning that 95.5 Rodeo for 2 days - dealership service rep accidently smashed it head on into a delivery truck.
1997 3.2L V6 Rodeo
Old 09-30-2005, 07:09 PM
Re: Re: Need input on a few quirks
After I posted I looked at the date of the original message... doh!
2007 Honda CR-V
Old 09-30-2005, 07:31 PM
No biggy.
It did have the LSD - it's too bad it got crunched, that was a nice rig.
1997 3.2L V6 Rodeo
