Old 09-20-2005, 08:34 PM
macder macder is offline
Send a message via MSN to macder
BDay bad luck
It's rush hour on the freeway, I disengage the clutch to shift and can't pull it outta gear. I try again and now the clutch pedal has no resistance. There really isn't a better time for a clutch to be stuck engaged then 5pm on a weekday. I pull to the shoulder and brake fluid is pissing from under the car. All the fluid in the reservoir has leaked out by now and air got into the hydraulic system. After getting underneath the car I find out the slave cylinder doesn't like DOT3 fluid anymore and let the pavement have it instead. I had to drive my car w/o the clutch all the way home and believe me, 1st gear was not a fun one. And all this on my birthday.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 09-20-2005, 09:09 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: BDay bad luck
that sucks, at least you made it home though.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-20-2005, 10:23 PM
Re: BDay bad luck
If I had a 10mm wrench and my wallet (forgot it @ home) when all this happened it wouldn't be so bad. I'd just buy some DOT3 at a gas station and bleed the clutch. Since it only leaks fluid when engaging/disengaing clutch, chances are I'd make it home before loosing all the fluid again.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 09-20-2005, 10:27 PM
Holset powered 420a
Re: BDay bad luck
maybe you should start carrying a tool set with you.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-20-2005, 11:38 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Re: Re: BDay bad luck
Yeah, i always carry mine with me. Thankfully i havent actually critically needed it yet. But im sure i will sometime.
Pictures of the Truck
Old 09-21-2005, 07:13 PM
Re: BDay bad luck
A tool set and a flashlight are a must in the car, but I must have forgoten to put the set back in after cleaning the car few weekends ago.
Last night I added DOT3 to the clutch reservoir, bleed the clutch, and made it to work in the morning. I then ordered an aftermarket slave cylinder through the company account, the thing cost me $23 and is listed @ $59.xx. Usually in a situation like this I'd just replace it on my driveway, but this DOT3 brake fluid is almost like acid. Took me less then 20mins to replace the thing at my shop.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
