Old 09-20-2005, 08:17 PM
d901j d901j is offline
Send a message via AIM to d901j Send a message via Yahoo to d901j
possible engine conversions????
I have a 98 eagle talon. I was wondering if any one has heard of any different conversions kits or any ideas. Will the mitsubishi evo motor work if I have the axles, tranny, motor, and computer. What else would I need. I had an idea to drop the evo in my talon and just have it front wheel drive. Any suggestions or laughs?? I know I would have to custom the mounts. but what else?? Thanx
Old 09-20-2005, 09:02 PM
macder macder is offline
Send a message via MSN to macder
Re: possible engine conversions????
If your non-turbo forget about swapping any mitsu motor into it. If your turbo then an EVO engine (4g63) is under your hood allready. Only yours is mounted 180deg opposite of a EVO VIII meaning tranny is on the otherside. The best thing to do is swap a 6-bolt 4g63. Key in "6bolt" into the search feature.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 09-21-2005, 02:25 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
why in gods fucking name would you convert an awd to a fwd?? that's like...worse than wanting to take the turbo off of a gst/gsx and just run it non-turbo.
95 Talon TSI AWD
97 Eclipse GST
