Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 09-20-2005, 07:56 PM
drastic1313 drastic1313 is offline
95 tranny problems
Gooday all
It seems the transmission in dodge products are quite the piece of work
I recently got a 95 Intrepid for dirt cheap with one problem-no reverse
the car goes fine in forward it will shift above 2nd
this is the third tranny in this car but the other 2 had the other problems
I generally read about in this forum
I have replaced the fluid with the proper Mopar fluid and filter
any other ideas would be helpful
thanks Ken
Old 09-20-2005, 10:13 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 95 tranny problems
your solenoid pack is probably bad. Go to a shop and have them see if they can manually engage the solenoids through a scanner. If it has problems working then, you have a bad solenoid pack. If you're going to pursue that, you'll also need to have your TCM reprogrammed, that's a standard procedure that has to be done whenever a solenoid pack is replaced.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
