Old 09-20-2005, 06:44 PM
travis712 travis712 is offline
Send a message via AIM to travis712
E.T. question about DSMs.
Im looking for a car that I can upgrade slowly and keeping things on a budget. For this reason, I was looking at something like a gs-t. Turbos are expensive, and if it came with one stock, then it would be cheaper then anything else. Im wondering what a gs-t with say, CAI, air filter, headers, and exhaust system(full) would run? I just want it to keep up with other slightly modded cars. And if I moved up to a bigger turbo, would it be a drop in or would I need to buy new equipment/hardware then stock? Thanks, and if I need to clarify anything, ask and Ill respond or edit.
Old 09-20-2005, 06:48 PM
Savior1974's Avatar
Savior1974 Savior1974 is offline
Re: E.T. question about DSMs.
No headers on a gst, but with intake, downpipe, and exhaust, you should be in the mid/low 14's...... low 14's high 13's in a gsx.....bench racing sucks.
1998 Eclipse GSX (Sold)
Act 2600, Apexi 3" downpipe, 3" exhaust, Hks 3"-5" muffler, Greddy TypeS BOV, Autometer Boost/Vac & Air fuel Gauge, Garrett T3/T4 60-1 turbo (Only boosting 15 psi) Tial 38mm Wastegate, Spearco FMIC, Greedy Profec B2, HKS Turbo Timer Type, Dejon Intake/K&N Air Filter, DSMLink, Eprom ECU, 950cc Fuel Injectors, Walbro 255 HP Fuel Pump, Aeromotive FPR, Drilled/Slotted Rotors, B&M Short Shifter
Old 09-20-2005, 06:56 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Also, for our cars (gst/x), there is no cold air intake. But, I have seen people fabricate some aluminum pipes so that it puts the air filter near the bottom of the front bumper.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 09-20-2005, 06:59 PM
Yea, Im a noob when it comes to the DSMs. Ive never really hung out in this forum, so my experience ids very limited.
Old 09-20-2005, 07:00 PM
Savior1974's Avatar
lol good point clipsekid99. I just assumed he meant intake. But no CAI for turbo dsms either.
Old 09-20-2005, 07:02 PM
Savior, what is your car running? just so I can see some numbers from people. And I do release you have a GSX.
Old 09-21-2005, 01:46 AM
kjewer1 kjewer1 is offline
AF - Advisor
It is bench racing, but at this point there is so much data it's easier to estimate what these cars will run. You didn't mention if you want a 1g or a 2g. The 1g is most likely your target since you mentioned a budget. and they are eaier and cheaper to make fast. With an intake and exhaust expect low 14s from AWD. With a little more boost, 13s. With fuel control/fuel pump and race gas, 12s. I have seen many times poeple with 1Gs just do intake/exhaust/pump/AFC/MBC run 12s. You need to have some idea what you are doing and some balls, but its not hard to do. But back on topic, expect low 14s on basic mods for AWD, and add a good half second for FWD to any estimates, more as it gets more modded. Just search around and check out poeples mod lists and times. Not always easy to find, but sometimes its in poeple's sigs.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
