Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-20-2005, 05:53 PM
D-Bo's Avatar
D-Bo D-Bo is offline
new clutch
finally got around to buying a new clutch. i got the act kit.. NX4 HDSS holds 267ft./lbs 'which is probably not any higher than i'll be making. spent $394USD including shipping.. how much have you guys paid to have clutches installed? i don't think i'd be able to do it myself but i know a guy who i could help..
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 09-22-2005, 12:51 PM
genkichild's Avatar
genkichild genkichild is offline
Send a message via AIM to genkichild Send a message via Yahoo to genkichild
Re: new clutch
Just did the same thing. Same clutch too. I paid $360 ish for the clutch after shipping and paid a shop another $350 for install.
Doing the install yourself isn't tehcnically difficult, but it requires a lift and a helper to pull it out. So, unless you got a lift, you need a shop...
Of corse, then you need someone good. In my case, I developed a new problem three days later. Now after the car gets warmed up (like 30 minutes driving), the friction point of the clutch moves right up to the top of the pedal throw, and it starts to slip. This goes away after I park for a day. At the risk of stealing this thread, anyone heard of this problem? Solutions? (other than going back and yelling at the shop guy, which I will have to do anyways)...
Old 09-22-2005, 12:52 PM
genkichild's Avatar
Re: new clutch
Oh, yeah. The reason the shop was so expensive was they re-finished my flywheel too.
Old 09-22-2005, 11:38 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
Re: new clutch
i paid 300 for my stage 3 spec clutch, but i got it off of a person not an actual shop.
-tim
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
Old 09-23-2005, 02:59 AM
D-Bo's Avatar
Re: new clutch
i think i'm just gonna find a hookup to get it done.. i know the owner of jrek autocare very well and he sends all his mechanical work to another shop (he's strictly detailing at his shop)..
alex, how's the clutch treating you now?? same deal? and when did you install it?
cory, didn't you put in the same clutch?? or was it tat?
Old 09-23-2005, 03:23 AM
coolbone28 coolbone28 is offline
Re: new clutch
its not too hard to do it yourself. re-surface of the fly shouldnt be more than $30. i changed my clutch with me and a friend with a jack. only took a coulple hours. just gotta use some muscle and determination. but hey if you cant find someone they i guess you have to pay. good luck tho
Old 09-23-2005, 03:49 AM
TatII TatII is offline
the tq rating for the ACT HDSS is very underated. there are a few people out there making around 400whp on that clutch and no problems. i'll let you know how it holds up when i get my new T04E in running 1 bar of boost.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 09-23-2005, 02:36 PM
NiSmO_zt's Avatar
NiSmO_zt NiSmO_zt is offline
Send a message via AIM to NiSmO_zt
Re: Re: new clutch
Originally Posted by genkichild
... In my case, I developed a new problem three days later. Now after the car gets warmed up (like 30 minutes driving), the friction point of the clutch moves right up to the top of the pedal throw, and it starts to slip. This goes away after I park for a day...
i had teh same prob with my new clutch, just lay your seat back, tilt teh wheel up and get under your dash by your clutch pedal, you have to adjust the clutch rod. there is a rod with locking nut attached to the clutch pedal, you need to loosen the nut, and turn the rod (counter-clockwise in your case) until the pedal just returns to the fully out position when you push it in and let go. then just tighen the nut back up, and done. its tight in there, and easy to get frustrating, but once youve done it once, its cake.
also remember, ive found that a little turn on the clutch rod goes a long way, its very easy to over-do it
peace
-bopp
my current 240--ka-t
Old 09-23-2005, 02:38 PM
Tims_240's Avatar
Re: new clutch
if your clutch is slipping hardcore, then you might need your flywheel resurfaced, just take a look at it, you can tell where the clutch smacks against the flywheel because that point will be lower, but in that lower portion if there is scratches or lowpoints then you need to get it resurfaced, otherwise i wouldnt even bother, i didnt resurface mine, mine was in real good condition, and mine sure is holding great.just trying to save you some time/money.
-tim
.s13 power.
Old 09-23-2005, 05:27 PM
genkichild's Avatar
Re: new clutch
I'll try out that clutch adjustment this weekend. Thanks for the input.
As far as the actual ACT goes, I love it when it is working. good clamping power.
