Old 09-20-2005, 04:45 PM
KawaiChik KawaiChik is offline
Send a message via AIM to KawaiChik
Exclamation Idling too high, esp in park
This just started today when I went to leave class to go to work. Needless to say the car is still parked where it was earlier... I have a 95 Lumina, it normally idles in park at around 500-1500 RPMs; however, today it shot up to 3000-3500 RPMs. It didn't go down while letting the car sit there, it just went up. When I put it in drive or reverse the rpms shot up and the car just about took off (I had to use the emergency brake as well as the pedal to stop it). Anyone have any ideas on what this might be before I get it towed to a mechanic?
Old 09-20-2005, 05:06 PM
starla3366 starla3366 is offline
Send a message via Yahoo to starla3366
Go to this thread.
http://www.automotiveforums.com/vbul...d.php?t=454660
2000 Blazer LT
4.3 vortec
75k miles
K & N FIPK
Old 09-20-2005, 05:46 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Idling too high, esp in park
Emissions controls will compensate for a vacuum leak with more fuel to balance out the combustion ratio.
Translation: Vacuum hose pops off, engine sucks air, ECM says "too much air, add more fuel".
Result: Idle way too high.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 09-20-2005, 07:41 PM
Talking
That was it, the vacuum hose to the master cylinder that had popped off. Thanks for the advice!
