Old 09-20-2005, 04:25 PM
zdc323's Avatar
zdc323 zdc323 is offline
91 Rs Speedometer cable
I'm replacing a speedometer cable on a 1991 Rs Camaro. I bought the car knowing the speedometer didnt work, but when I went to see why, there was no cable at all, none whatsoever. So after a little while I bought a speedometer cable replacement kit. Looking at the kit now I realize I may not have everything I need. I have the cable, but do I need a cable casing? And if so where could I find one. Thanks
Old 09-20-2005, 05:52 PM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
Re: 91 Rs Speedometer cable
i had a 92 rs and the speedometer doesnt use a speedometer cable which is probably why you couldnt find a cable on it...the problem with mine was a clip in the transmission and it was $5.95 to fix.
Old 09-20-2005, 06:48 PM
zdc323's Avatar
Thats weird because I looked into a repair manual and its got a section on speedometer cable replacement. Anyway, do you know what the chp was called?
Old 09-20-2005, 06:58 PM
666_speed's Avatar
Son of Satan
sorry no i dont remember it was around 3 years ago i had that car and the speedometer didnt work when i bought it and i went to chevrolet garage and asked about ordering a speedometer cable for it and they tried looking it up but they couldnt find one in their catalog so i went and talked to a mechanic and he told me they didnt have speedometer cables and he fixed it for me...mine was a 92 so it may be different...i was thinking they were the same but i may be wrong.
Old 09-20-2005, 07:04 PM
zdc323's Avatar
Im pretty sure 91 and 92 are the exact same...maybe 92s different because its anniversary or something. Thanks for your help though
Old 09-20-2005, 09:53 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
91's are the same, it's electronic, there's a part on the tailshaft of the tranny that has a wire harness plugged into it, when you unbolt that part and pull it out it will have one of the speedo gears on it, the "driven" gear if i recall correctly. your problem probably lies there or within the cluster itself.
Old 09-20-2005, 10:22 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Re: Re: 91 Rs Speedometer cable
if you got a repair manual that is for all third gen camaros... then it would cuz earlier third gens did use cables... yours does not
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 09-21-2005, 12:17 AM
ct91rs ct91rs is offline
Re: Re: Re: 91 Rs Speedometer cable
If that's the only gauge that doesn't work, I think you need a new VSS (vehicle speed sensor).
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson
Old 09-21-2005, 02:36 PM
zdc323's Avatar
First off...thanks for the help, I realize now that there is no cable at all. Secondly I would imagine the problem is the speed sensor...I just called a local shop and they said itd be 60 bucks for the sensor... Am I missing something? Speed said his was a 6 dollar fix
Old 09-21-2005, 03:40 PM
He said, "the problem with mine was a clip in the transmission and it was $5.95 to fix." I take it he didn't need to replace the speed sensor. He may be referring to just a wire pigtail. $60 is about right for your VSS.
Old 09-21-2005, 08:07 PM
666_speed's Avatar
Son of Satan
yep it was $5.95 for the part that fixed it, he charged 70 in labor to fix it....but anyways yep $5.95, no it wasnt the speed sensor but its been so long i cant remember what it was exactly
