Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 05-13-2002, 09:57 AM
lloyd_nickens's Avatar
lloyd_nickens lloyd_nickens is offline
Resetting ECU
Are there any real performance gains from doing this??
"God Bless BASS, What Would We Do Without It?"
"If You Can Breathe, Turn The Music Up."
Old 05-13-2002, 12:19 PM
NismoPC's Avatar
NismoPC NismoPC is offline
No.
The reason you would want to reset the ECU is if you advanced timing, installed a pop or CAI, a new header, cams, exhaust, etc. The ECU has to relearn the change in timing, the air/fuil mixture from the intake, the change in exhaust flow exiting the car and/or the change in the cam durations.
It will just help keep things running smoother.
Brandon
'96 G20 - modified
Old 05-13-2002, 03:43 PM
Ah, now all makes sense!!
Old 05-13-2002, 09:22 PM
NismoPC's Avatar
Just a side note:
It'll take about 20-30 mins of driving the car for the ECU to start using the upgrades properly!
Brandon
'96 G20 - modified
Old 05-15-2002, 10:45 AM
cool. so should i reset my ecu after every upgrade or should i wait every couple of upgrades
Old 05-15-2002, 10:49 AM
NismoPC's Avatar
It's all based on personal opinion. I try to always reset the ECU every upgrade. It only takes 5 mins or less.
Brandon
'96 G20 - modified
Old 05-15-2002, 12:59 PM
right.
I actually tried it to see what would happen. Here is what I found: after driving around town with the ac on the car felt sluggish--resetting the cpu removed that feeling. also the car felt a little quicker even with it being full of passengers.
Now it could have been me, but my friend also drove it and noted how much peppier it is.
Resetting ECU- 1995 Toyota Camry V6 XLE Techniker Camry/Camry Hybrid/Vista 1 07-07-2010 08:42 AM
reset ecu? flipkid 3 Series 1 01-17-2002 09:25 PM
Reset ECU??? 2002G20Racer Engine 1 11-04-2001 01:55 AM
Resetting ECU Soleman20 Engine 1 09-18-2001 10:45 AM
reset ecu Sleepy Engine 1 09-09-2001 01:34 AM
