Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-20-2005, 02:27 PM
mastaplaya224 mastaplaya224 is offline
EGR Valve replacement
How do you do it on a 99 Neon R/T?
Old 09-24-2005, 07:05 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: EGR Valve replacement
If you are just replacing the EGR valve, then you will first have to remove your intake and battery. Then locate the EGR valve. I believe there are two 10mm bolts that attach it to the side of the head. They are not easily accesible but with some extensions and a good socket, you can get to them. Remove those two bolts and then the two that connect the EGR valve to the tube. The other two are a bit easier to get to but you will probably need an extension. After you get those 4 bolts out, you should be able to pull and wiggle your EGR valve out. Replacement is the opposite of removal. Don't forget to get a new gasket where the EGR valve connects to the tube.
Old 12-10-2005, 11:49 PM
m2736185 m2736185 is offline
so where is the EGR valve located exacly? I found the solinoid, it it near there? I have a short ram intake installed so there is no air box to remove.
Old 12-11-2005, 10:50 AM
Re: Re: EGR Valve replacement
Locate your throttle body...you will see a tube underneath running upwards diagonally to the back of the engine...Its on the side of the engine below the valve cover but further toward the back of the engine.
