Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 09-20-2005, 11:54 AM
wildbillponca wildbillponca is offline
Exclamation HELP!! Code P1870 what do we do?
Hi. We went to Autozone and they checked the codes and it said code P1870. I looked it up on here, but it doesn't say what needs to be done to fix it. Any ideas?
Old 09-21-2005, 10:35 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: HELP!! Code P1870 what do we do?
A transmission component slipped and the computer caught it...might be a clutch pack or the torque converter clutch. If the transmission fluid has never been changed, it's now time and may solve the problem because low trans fluid pressure due to a clogged filter will also let a component slip causing the trouble code. I'd have a general repair shop do the filter job to avoid feeling bad about your favorite trans shop if this doesn't fix your problem.
Old 10-04-2005, 10:07 PM
drdd's Avatar
drdd drdd is offline
P1870 does mean component slipping. The valve-body is usually the culprit there. I do agree with the previous post ... try changing the filter and fluid first to see if that doesn't do the trick ...
Old 10-05-2005, 06:48 AM
blazee's Avatar
blazee blazee is offline
Problem?
http://www.automotiveforums.com/vbul...d.php?t=465771
