Old 05-13-2002, 08:03 AM
jtrres jtrres is offline
which sub to go with
hey im not sure which sub to with.What i want is my windows and mirrors to rattle when i play my rap music. i want cars next to me to feel it when im at a red light.but i dont want to spend to much. if you guys could give me some opinions it would be helpful: Alpine type R swd-1241d
SPECS:
Size 12"
Impedance 4 OHM + 4 OHM
Power Handling 1000 WATTS /300 WATTS RMS
Frequency Response Fs-1kHz
Sensitivity 87db
D.C. Coil Resistance (RE) 3.6
Inductaance (LE) 1kHz/20kHz 2.38mH/ 0.85mH
Free Air Resonance (Fs) 26Hz
Equivalent Stiffness (Vas) 66L
Qms/Qes/Qts 10.39/0.38/0.37
X max/ X peak 12.9mm/ 25.8mm
Mechanical Excursion (P-P) 55mm
Gap/ Coil Height Hag/HVC 10mm/35.8mm
Cone Area (Sd) 467.59cm2
Diaphragm Material Kevlar Reinforced Pulp
Spider Material Nomex
Magnet Weight 89.4oz
Voice Coil Diameter 50mm
Recomended Sealed Box Volume 0.7-1.0 f 3
or
Audiobahn AW1251x 12"
Features
· 45 oz. Strontium Magnet
· Power Handling: 400 watts R.M.S.
· Frequency Response: 24Hz - 1kHz
· Efficiency: 92.1 dB
· PHAT Foam Surround
· Non- Pressed, Non-Transfer Paper Cone
· KM3 Coated for Virtually No Cone Distortion
· 2 Inch 4-Layer ASV Voice Coil
· Dual 4 Ohm · 2 Ohm or 8 Ohm Operation
· Depth: 5 1/4 Inch · Hole: 10 7/8 Inch
· Diameter: 12 Inch
Old 05-13-2002, 08:21 AM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
depending on how much subs you're getting, you can take the alpine out. they are more of a Sound Quality sub. no doubt they can get loud, but you'd have to have at least 3 of those. the audiobahns would be more of what you want. 2 would work fine, just port the box. how much can you spend on one sub?
I love them sub wufers
Old 05-13-2002, 12:39 PM
94civic's Avatar
94civic 94civic is offline
i got 2 alpine swr-1241d's wired at 2 ohms and they are in a box about .78ft^3 per side and i was playing around with them yesterday in my basement and hooked them up to my home stereo reciever sending about 100watts rms and they shook the windows on the second floor. well thats what they said upstairs. i think you should go with the alpines.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 05-13-2002, 02:43 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Im going to have to go with the Audiobahn Aw1251x on this one... I used to run 4 of those bad boys off 1600 watts and let me tell you -- it would flex my damn windsheild! It was crazy... But yeah, all depends on your car and what you are looking for. The AW1251x in a sealed enclosure will provide better then average SQ and if you make the box slightly larger then recommended specs you will also get some good boom! :smoka:
AF's Official Asshole
RIP AUNIE
Old 05-13-2002, 04:26 PM
I was looking to spend around 120 for each sub and i seen the aubiobahn for about 90 bucks and i figured that was a nice price for 400 watts rms
Old 05-14-2002, 09:56 AM
JayFidizzy's Avatar
JayFidizzy JayFidizzy is offline
Banned
Send a message via AIM to JayFidizzy
Audiobahns are great that would be a good choice.
JL Audio is really good too but a touch on the expensive side.
Old 05-14-2002, 10:58 AM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
But damn well worth it to hit mid 140s with 1 sub and 500 watts.
Old 05-14-2002, 11:17 AM
JayFidizzy's Avatar
Banned
damn straight.........the stealth boxes are off the hook
Old 05-14-2002, 11:38 AM
My plan was to get 1 15W3 for my car, and call it a day, but I ended up buying the aluminum cone eclispe 12" since I got such a deal on it. I think it's awesome, but that 15W3 POUNDS in my car! At least I don't have to give up so much airspace with the eclipse
Old 05-14-2002, 08:07 PM
GSteg's Avatar
yea, the 15W3 is an awesome sub. they can take even more than 1500watts if carefull. i remember one guy did over 150dB with it. simply awesome...
