Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-20-2005, 10:20 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Unhappy Ok... Im stumped...
Ok, as someof you know, im running a b18c1 in my 93 Civic EX.... im running Uberdata with closed loop disabled because im running it off my PLX M-300 for datalogging... now whenever the car is running and i hit the horn OR unlock my doors using the door lock button, it throws a CEL... i pulled the codes off my ECU and the only one is a Solid CEL, which i believe is the ECU code... but other than that it runs fine... any ideas? i sorta need this fixed by the end of the month so i can get my inspection sticker... Thanks in advance.
Old 09-22-2005, 12:14 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Ok... Im stumped...
that is interesting. post results when you get it figured out.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-22-2005, 01:19 PM
Kind of a Big Deal
I deff. will.... i really have no clue what it is... ive quadruple checked all my solder points and wires and its all fine....
Old 09-22-2005, 02:55 PM
97integrals's Avatar
97integrals 97integrals is offline
Because this is swap maybe some wires got crossed during the build. This is very weird I've never heard of this problem before. I feel bad for you, because there is nothing I hate more than electrical problems!!
Old 09-22-2005, 03:04 PM
Kind of a Big Deal
i dont think that could be it, because i ran the new engine for 5000 miles before this started happening.
Old 09-23-2005, 06:53 PM
DUI DUI is offline
Send a message via MSN to DUI
Grounds, check em all, alot of times if you are running any kinda external connection system their can be residual energy. i would take the time to get a ground kit for your non-engine components. make sure the solder hasn;t over heated and maybe dizzled somewhere. like 97 said, theres probly something crossed or even more likly touching. another question, do you have the right ECU in, is there a engine man. or do you have a piggy back. i had a simular problem in my accord.
'92 Honda Civic EX 4DR 5SPD:
AEM V2 intake
Skunk2 intake manifold
DC 4-2-1 2 piece headers
Skunk2 MEGA power exhaust
APC short shifter
Centerforce stage-2 clutch
ATC stage-3 8lbs flywheel
Old 09-24-2005, 04:20 PM
Kind of a Big Deal
its a b18c1 running a chipped p72. and ive checked all the solder points, nothing it touching... i talked to a mechanic who said not to worry about it cuz the car still runs fine after it comes on....
