I don't understand it my hazards work and every thing,but the hand book for my 88 stationwagon says my signaling system is malfuntioning,how do you fix that,please if you know HELP!! I don't like using hand signals.
Re: Blinkers won't work.
Are all the bulbs good? Maybe the turn signal switch is bad.
could you tell me how to replace a turn signal switch? my hazard flashers and turn signals both don't work, so maybe that is it? also, do you know where it's located?
nemets88- what year is your car? Turn signal switch is the lever on the steering column. First you need to check to see if you are getting power through the switch. Did you check the fuses? Are the bulbs good? Are you getting power to the sockets? A wiring diagram will help trace the circuit. Try your local library for a repair manual to get instructions on how to replace the switch(es).
thanks for the help, and btw, my car is a 97
