New Cams Question
Just wondering if anyone knew the disadvantages of having N/A stage 2 cams on a Turbo car, I plan on going turbo in the possibly distant future, but i'd like to get a kick in the pants for my car now so would turbo be bad w/ n/a cams or are turbo cams bad w/ N/A, mostly wondering which is the better option for right now
any help is great
![]() Don't act like you don't love it.
503/2000 |
Re: New Cams Question
it depends what "stage 2" was designed for. with a turbo, you can't have much overlap and most N/A cams have a lot of overlap.
Dr. Disque - Current cars: 2008 BMW 135i M-Sport 2011 Mazda2 Touring Past cars: 2007 Mazda 6S 5-door MT 1999 Ford Taurus SE Duratec |
mmm cool thanks
503/2000 |
you also have to consider you only have 1 cam...
MODS , 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo and the ac still doesn't work and its been almost 3 years |
...SOHC yeah... the cams i was looking at are rpw ones, hardly worth it to buy some then switch later on, especially since i'll have to have a shop put them in, then tune it
503/2000 |
Re: Re: New Cams Question
i think he means i can't use a combination of cams like the 264, 272 combination popular w/ the 4g63, that or he was trying to be a smartass... eh whatever
503/2000 |
how the hell does that work? It you have 2 cam shafts than you would be dohc (correct) And the 2000+ came with a 3 liter v6 sohc 200hp gts 210. No i wasn't trying to be a smart ass but as far as i know you only have one cam.. that controlls the intake and exhaust. The 264 and 272 is good but its better to have 272 / 272 the real reason for the 264 intake is so that your idle isnt all rough. Also i guess it will change your power band quite a bit but thats not the point.
there is a cam over each head(SOHC) but it has two heads. |
look it up next time,and i kno 272's all around are for strictly power, the 264 combo 272 (what i would use if i had a dsm) is for a cleaner idle, at least half the guys i kno w/ turbo cars have dsm's, i'm not entirely illiterate
503/2000 |
