Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-20-2005, 09:29 AM
smats4 smats4 is offline
Question Blower fan quit working
My 16 year old son installed a stereo in his 1988 Chevy Caprice Classic, and now his blower fan doesn't work. Therefore, his defroster doesn't work. I'm trying to get a diagram or some info on the wiring to the blower motor, and have had no luck. Any ideas?
Old 09-20-2005, 01:36 PM
CD Smalley CD Smalley is offline
Re: Blower fan quit working
Wow, two stereo installs and two electrcial faliures...
Are you and babiarz related?
Just kidding. That's just such a coincedence.
Does the fan not work at all?
Does it work on all but High or anything but High?
If it doesn't work at all, take the handle of a screwdriver and whack it good a couple of times with the switch On. It if takes off and starts working, replace the blower. If not, well I'll start digging for the wiring diagrahms and the software to make my scanner work....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 09-20-2005, 03:25 PM
Re: Re: Blower fan quit working
No, it doesn't work at all. I'll try whacking it and see if that helps. Thanks for your quick response.
Old 09-20-2005, 07:55 PM
400wagon 400wagon is offline
Sometimes the connection on the fan itself gets corroded. look under the hood and there should be a harness type thing that clips onto some connections on the fan itself. I've had some chevys that that was the problem. I took some sandpaper and roughed up the terminals and it worked better, although it could have nothing to do with what is wrong with your car.
Old 09-21-2005, 08:26 AM
After working on it some more, we now have power up to the relay. I am going to try putting in a new relay and see if that helps.
Old 09-23-2005, 08:45 AM
Okay...I put the new relay and that didn't help. Any other suggestions?
Old 09-23-2005, 06:53 PM
Getting power to the fan itself? If so, then replace the fan IMHO.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 09-29-2005, 08:51 PM
CAPRICE LIFE CAPRICE LIFE is offline
Send a message via AIM to CAPRICE LIFE
wut is the fan IMHO?where is the relay located.ihave the same problem.i just didnt put a stereo in i put a engine in.lol
IF IT AINT BROKE,DONT FIX IT
IF IT IS ASK ME
Old 09-29-2005, 09:37 PM
In
My
Humble
Opinon
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 10-05-2005, 07:55 AM
runedawg runedawg is offline
Make sure he didnt unplug a relay ar connection under the dash when he put the radio in that happened to me in an 87 Camaro. Naturally I thought the worst but it turned out to be an easy fix.
On another note someone mentioned the blower working on all speeds but high. My 78 Caprice is doing that now. I have already relaced the switch ( 3 times ) and the high speed relay by the blower motor. What causes this?
Old 10-05-2005, 01:32 PM
kahjdh's Avatar
kahjdh kahjdh is offline
I dunno about caprices but the blower motor on my wagon is right out in the open so i would take it out and test it. Hook a battery up to the motor and see if it works.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
