Old 09-20-2005, 08:21 AM
ipitch ipitch is offline
Squeaking in right front
I have a loud squeak in the right front of my 2001 Blazer. It seems to get worse when the weather gets colder. I recently had ball joints replaced, rough roads really make it squeak. Can this possibly just be a worn shock ???
Old 09-20-2005, 08:34 AM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Squeaking in right front
I will assume that it is not a brake squeak, or a bad wheel bearing, and that it is front-end suspension related.
Old 09-20-2005, 02:11 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Ball joints need to be greased again. 11 grease fittings in your front end that have to be greased.
http://www.automotiveforums.com/vbul...d.php?t=344505
You have a dry ball joint or a poor quality ball joint was installed.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-20-2005, 04:28 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I agree, grease the fittings. Also, not sure if this will help but it did help me. I took white lithium grease, the spray kind, and I sprayed in bewteen the leaf springs, any metal to metal or metal to ruber or moving parts on the chassis and really quietted things down for me. But that is an option, greasing all 11 fittings is a requirement. I use Mobil all tempreture grease. Believe it or not I use the mobil low temp grease on my snowmobile, does not make a mess and stays where you put, never seems to fly off. Great product.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
