Old 09-20-2005, 06:57 AM
[email protected] hans@geier.us is offline
Turn Signal Issue
I have an issue where the turn signals will not flash. All bulbs are functional and the emergency flashers work. Is there a fuse or something that controls the turn signal flashing?
Thank you in advance.
Hans
Old 09-20-2005, 09:07 AM
_Dark_Flash_ _Dark_Flash_ is offline
the fuse is in cavity 8 on your fuse box I'm pretty sure, it's a 20 and it's yellow
Old 09-20-2005, 09:21 AM
89ltd 89ltd is offline
Re: Turn Signal Issue
what year is this rig, sounds like it could be the flasher, depending on the year, they have a flasher for the 4 ways and another for the turn signals.
Old 09-20-2005, 10:06 AM
It is a 1994. Is the flasher under the hood or in the kick panel?
Old 09-20-2005, 10:24 AM
I have the service manual for the 93 and it shows the flashers on the fuse block under the kick panel, the flasher is round and plugs in, turn signal flasher is the top one and 4 way is the bottom, I think they are the same so you could swap them to test it.
Old 09-20-2005, 10:35 AM
some later models have a combination flasher , turn and 4 way in one unit.
