Hi,
Hi Everyone, I'm hoping that someone in the forum can help me. It looks like a great place to get some answers. Just glad to be here!!!! I live in Canada, and have a 1992 Ford Taurus 4d car. I'm looking for any help in maybe trying to solve the reason its not passing emissions testing. The only part that does not pass the emissions test is the NOX? The limit at a fixed speed of 40km per hour should be .450 and our vehicle is coming in the .825 ? I have another question that no mechanic will freely answer and that is, if there was a problem with the egr valve or any of its parts, would the "check engine" light come on? Or do i assume that since we have had not check engine lights come on, that the egr system is working fine? Any help would be greatly appreciated... Where running out of time. |
Re: Hi Everyone, i'm new here and need some help?
Re: Re: Hi Everyone, i'm new here and need some help?
Hi Manuel!
Thanks so much for your reply. Just last night my husband and a friend of his, who is a mechanic took the egr valve off, and did a pressure test to it. You could see the little piston inside moving up and down freely and it would also hold pressure? My husband also blocked the manifold (i think thats what you call it- its the part that the egr is connected to) and then we started the engine, it has soo much vacumm he couldn't remove the piece covering that spot until we turned the engine off! Many people have said that it is the Catalytic converter, but then others say that the hydro carbons would be high in the emissions test if the cactalytic converter was no good? We are getting no """Engine""" lights on at all???? Everyone has been guessing but no one has the answer. This car runs awesome, it doesn't misss, or anything, it passed 2 years ago no problem, its just this NOX problem has got us stumbled. Any other ideas would be greatly appreciated. Thanks again for replying. 99mallard Quote:
Re: Re: Re: Hi Everyone, i'm new here and need some help?
Re: : Hi Everyone, i'm new here and need some help?
Hi Manuel,
Well it turns out our vehicle is not equipped with the acutator, and ours is a 2 way catalytic converter. This one has everyone stumped????? Any other help would be appreciated!!!!!!!! Thanks so much!!!!!! 99mallard Quote:
If it appears that the valve is functional from your vacuum tests, I agree with the suggestion to check the vacuum line to the valve. From what I know of these guys, the EGR valve is shut (no vacuum) when idling and opens up when the car is at some predetermined RPM. A failure mode is the valve stuck open, and that results in a very rough start from a standstill. If stuck closed you get no perceptible performance problem but will fail the emissions test on a dynamometer. |
Thanks, The egr valve is working perfectly, my husband has removed it and applied vacuum to it and you can see the valve open and close easily and it holds pressure with no problems. This car runs great, it starts perfectly with no hesitation, it hasn't run this good in a long time. Someone, a friend suggested retarding the timming back 4 degrees to make it pass???? Any thoughts on that one??? I know we have to do this with my sisters car every two year, if we don't retard her timming back, it fails, we bring it home and retard it and take it right back and it passes with flying colours. Some people say this is the only way to get some vehicles to pass? Thanks for your input. 99mallard |
Re: Re: Re: Re: Hi Everyone, i'm new here and need some help?
Thanks so much for your continuing effert to help. No, there is no green vacuum line on this vehicle, its just a regular 3L V6 engine. It does however have the solenoid, and my husband has replaced that just the other day. Again, thanks for all your input, its much appreciated. 99mallard |
Re: Re: Re: Re: Re: Hi Everyone, i'm new here and need some help?
Re: Re: Re: Re: Re: Re: Hi Everyone, i'm new here and need some help?
thanks for all your help. 99mallard |
Just wanted to let you all know that we finally got the car to pass the e-test. Thanks for all your help. |
Every element of the etest was even better then before, even ones that passed before, were almost perfect this time??? go figure!!!!!!! Thanks for all your help!!!!!!!!!!! |
There is an octane adjustment you can do to reduce NOx. Instead of manually retarding timing, you remove the shorting bar and it adjusts things properly for the PCM. It is located under the hood towards the firewall just under the plastic cover on the passenger side near the distributor. It's a wire connector that looks like it has a plug in it. Pull the plug and your done. That should help for a more permanent fix, plus it will run smoother.
