Old 09-20-2005, 02:01 AM
foon foon is offline
Hey i changed all the oils, plus fix the chattering problem!
Hello people,
Not posting a question this time haha.
i drive a 2000 bravada with about 74500 miles on it with no fluid change what-so-ever which explains why the gear oil that drained out was black, no joke. And the transfer case fluid was blu-ish black
Just happy that i change all the oils in my car today, and fix that chattering problem. Changing the transfer case fluid once stopped the chattering. Now making u-turns or tight turns the front end of the truck doesn't feel like its hopping and is not making that grinding/growling noise.
p.s Have a great day every day!
And heres what i learned.
1) 3 Quarts of gear oil is a little more than enuff for both front and rear diff. And 3 quarts of AutoTrak II is more than enuff.
2)The rear diiff screw is on side of the diff.(passenger side), also found out that a hex key CANNOT unscrew the bolt, just use a rachet with an extension, perfect fit. Its a square bolt, not hex.
3)Nappa sells a suction pump for 11.99 while autozone sell for 7.99.
4) Still can't remember which way to turn the bolt to loosen bolt
5) IF not using a jackstand, stretch for at least 15 min before crawling under the car, the bolts are tight and can def easily pull a muscle.
6) After the rear diff finish draining there is still a few more ounces in the diff. that didn't drain out, use the suction pump and get it out.
Old 09-20-2005, 10:03 AM
DINO55's Avatar
DINO55 DINO55 is offline
Re: Hey i changed all the oils, plus fix the chattering problem!
Good Job foon, Thanks for the Update.
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 09-20-2005, 11:56 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Good job buddy. thanks for the input and comments
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-20-2005, 02:06 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Nice!
I hope you used transmission fluid in the transfer case.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-20-2005, 04:15 PM
BlazerLT, You run all synthetic fluid correct?
K&N Air Filter
Old 09-20-2005, 06:41 PM
BlazerLT's Avatar
AF -Advisor
Yes, but not right at the moment seeing I am still doing the Auto-RX rinsing cycle for 3000 miles.
Then I will be back to synthetic permanently.
Old 09-20-2005, 06:48 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
It sounds like he used Autotrack II for his transfer case which is correct (not automatic transmission fluid).
Old 09-20-2005, 07:36 PM
Re: Re: Hey i changed all the oils, plus fix the chattering problem!
But aren't you running all synthetic fluid as in tranny fluid and everything else?
K&N Air Filter
Old 09-20-2005, 07:51 PM
BlazerLT's Avatar
AF -Advisor
Just checked, yes, they can both be used although I would use ATF seeing it is cheaper.
Old 09-20-2005, 07:53 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Hey i changed all the oils, plus fix the chattering problem!
Due to financial constraints, I can't switch them right now. I just had the diffs and the transfer case changed a little over a year and a half ago and the fluid is practically still new in them.
The transmission fluid was also changed but I could not afford the synthetic upgrade at the moment.
Old 09-20-2005, 07:59 PM
Re: Re: Re: Re: Hey i changed all the oils, plus fix the chattering problem!
What kind of gain might be seen form that?
K&N Air Filter
Old 09-20-2005, 08:33 PM
BlazerLT's Avatar
AF -Advisor
Fro the fluids, you might not see any improvement to slight improvement in warmer climates but where you will see a 2-3mpg difference is in the colder climates where temps drop less than freezing and lower.
Old 09-20-2005, 09:57 PM
Cool thanks. Might be something to do for a future venture
K&N Air Filter
Old 09-21-2005, 08:04 AM
blazee's Avatar
blazee blazee is offline
Problem?
Yep, ATF would have destroyed his transfer case.
Old 09-21-2005, 09:50 AM
biv343 biv343 is offline
ATF won't be cheaper in a Bravada after you've smoked the transfer case out of it....
