Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-19-2005, 11:51 PM
DrRifter-X DrRifter-X is offline
need help, car dying again
well back to the same problem. my car is dying once again when no pressure is applied to the gas pedal. most of the time it will die. sometimes it'll struggle and keep itself alive. other times it'll idle at 500 rpm then raise and drop. the problem came back just yesterday. also around 2700 rpm, right before i shift, its as if the car is struggling. and sometimes during the lower gears when i dont step on gas the exhaust makes a noise. it kinda sounds like its suckin air? im not too sure how to describe it. this happens sometimes and sometimes it doesnt. it was also smoking. i dont know what color because it was at night and i just saw it from the headlights behind me. i dont really know what is wrong. does it seem like a o2 and tps sensor problem? i ordered/bought a tps sensor but its being shipped to autozone and should be there wednesday. then i bought a o2 sensor but its not fitting.
i know this is a dumb question, and i havent worked on a car. this is my first car. do i take off that bigger nut piece that fits into that hole onto the exhaust? the bosch one i bought doesnt screw onto the exhuast hole at all. its too small. but the one thats in there has like a bigger thing on it. that goes onto the hole.
Old 09-20-2005, 11:59 AM
wotandsdwys wotandsdwys is offline
yeah, put a wrench on the nut that screws into the manifold.
and first thing I thought of was o2.
Old 09-20-2005, 12:34 PM
LT1-Power LT1-Power is offline
Banned
Re: need help, car dying again
brakes work?
Old 09-20-2005, 03:30 PM
travis712 travis712 is offline
Send a message via AIM to travis712
Im sure if your car didn't have brakes you would ask about that, not an idle issue.
Old 09-20-2005, 04:13 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
Ok...
This seems to be a pretty common problem for 240s I would give your AIV a cleaning...I need to as well. heres a link to some info on it.
"I had been having what felt like clutch slippage, kind of cyclic bogging down, in low revs. Car didn't lack upper end, or bother on hills though. I went through the bother of getting to the AIV, removing the top, and rinsing it out with electrical contact cleaner (its what I had, as I was also degreasing All contacts). (my speedo still wonk work right.) On removing the top clamp, the valve unit, was stuck. Some gentle pulling released it. The valve had to be stuck to some degree. Clean, bolt it back up, no bogging. Engine breaking smooth again. I feel (without real evidence) that this could be an additonal idle-type problem. I did have the unit replaced prior due to catastropic engine stalling when pushing the clutch and breaking. The unit seems to be easy to clean. I feel silly now for having it repla$ed.
Idle problems should include: MAF, MAF connectors, AIV, AIV connectors...."
Quote from 240sx.org FAq's give that shot it seems to be what is the problem most often.
And heres instructructions form 240SX.org FAQ's as well
"The AIV is easy to do. We suggest NOT removing the whole assembly from the car. Just take a real hard look at it and find the 4- screws that hold the 2- halves together. Remove the small vacuum line to the top, the larger one, and take the 4- screws off. Pull the top half off and there is a kinda "cap" over the reeds. GENTLY pry the assembly out of the housing. There are 2-sets of reeds. We only did one at a time so we could see how they went back together. With a wire brush and a can of carb cleaner, all we had to supply was a little elbow grease."
Old 09-20-2005, 04:56 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: Re: need help, car dying again
Originally Posted by LT1-Power
brakes work?
doesnt really sound like a vacuum problem... also it prolly wouldnt be smoking if it was just a leak.
Old 09-20-2005, 10:52 PM
klone420 klone420 is offline
I'd say the MAF/AIV sensors, I'd also make sure you didn't blow the head gasket.(change your oil and look at the color(dark brown-black=Ok),If it looks like mud u blow the head)
Old 09-20-2005, 11:29 PM
FatAlbert85's Avatar
FatAlbert85 FatAlbert85 is offline
Check two things: MAF and your distributor. The distributor can be off a tooth, mine was. It did the same thing. Same thing with my MAF now. Almost same problem. Struggles like my motor's boggin down in lower rpm range.
*Remember, straights are for fast cars, turns are for fast drivers!*
Old 09-21-2005, 12:12 AM
i know when my car is outta brakes or not. maybe if theres a jackass sensor it will be going off right now.
Old 09-21-2005, 12:20 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
what is a AIV?
air intake valve?
RX-7 TII
Old 09-21-2005, 06:45 AM
Re: Re: Re: need help, car dying again
Goodjob almost understanding my post.
I was referring to lt1-power, but good effort trying to look e-cool.
Old 09-21-2005, 01:20 PM
R.W.240's Avatar
Banned
Re: Re: Re: Re: need help, car dying again
LT1 Power was asking about the brakes because brakes are vacuum assisted... so when that hose pops off or cracks your brakes wont work well (or atleast as they normally would) and neither will your engine.
and once agian... I doubt its a vacuum issue...
Old 09-21-2005, 01:32 PM
Re: Re: Re: Re: Re: need help, car dying again
I realize this. But I suspect he would say something if his brakes didn't work at all.
Old 09-21-2005, 03:25 PM
put a resistor in the MAF sensor(the part with the wires)and run the car if its fine u know what the problem is. also tell us what color the smoke is.
Old 09-21-2005, 04:25 PM
monooxide's Avatar
Banned
I would bet...
I would bet its blackish smoke and its because he running rich.
