rough idle
i got a 94 camaro automatic v6 and when im stopped at a light stop sign whatever if im pressing on the brake while my car is in drive my car starts to shake a grip, i change my spark plugs awhile back like 2-3 months ago so im pretty sure its not that any help is welcome thanks
Re: rough idle
What's a grip? is that the same thing as a lot in cool peoples terms?
1994 3.4L Chevrolet Camaro - No more 2006 Hyundai Sonata |
Re: rough idle
1 Gap in plugs wrong
2 Bad wires 3 One of the coils failed 4 vacuum leak 5 low fuel pressure 6 Dirty TB and IAS 7 Lost comression on one cylinder (stuck lifter) How is the perfomance at different speed? Mileage? How many RPM at idle? How bad is shaking? Any codes or drivability probs? |
Re: Re: rough idle
![]() How 'bout an EGR sticking open?
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson |
Re: rough idle
Or just put the wires back in the wrong order?
Re: Re: rough idle
Re: Re: Re: rough idle
Re: rough idle
It might, just by some lucky coincidence though, or possibly the will of god...
Re: rough idle
- Jason 1995 Pontiac Firebird ![]() ![]() User Guidelines | VB Codes Explained | AF Merchandise "Each of us, is in the scheme of things, insignificant. But millions of insignificant people, doing a tiny bit, can add up to be a very significant force." |
Re: rough idle
Actually, my dumb ass did it (wired 'em up wrong). Just makes it feel like it's missing. Not even very violent, until you hit higher rpm's.
Re: rough idle
My car has a little bit of a rough idle as well especially when its a cold start in the morning. I think it has to do with my iac goin or its sticking. I wanna get some seafoam and run it through to clean everything out.
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Re: rough idle
IAC is the issue. ITs probably dirty.
Re: rough idle
tyhre should a code as well or some sensor just failed
Re: Re: rough idle
