Old 09-19-2005, 09:36 PM
_Dark_Flash_ _Dark_Flash_ is offline
Unhappy HELP! Diesel in my cherokee!! -- SOLVED
my friend accidently put 4 gallons of diesel in my 92' cherokee!
I put 10 gallons of premium fuel in it (it already had 5 gallons of regular) and tried starting it up again, and it starts and I can rev it a few times but then it shuts off again it feels like the pumps not putting gas up there, could it be my oxygen sensor?? when I rev it, it smokes out the back so I know it's burning the diesel but it won't stay on long enough for me to do much please help!
GOT THIS ALL SOLVED, DILUTE IT DOWN AND DRIVE IT A LITTLE BIT THEN CHECK YOUR PLUGS, (Note I had 4 gallons of diesel to 16 of unleaded)
Old 09-19-2005, 09:38 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: HELP! Diesel in my cherokee!!
should have had it drained and not tried to start it...but that's all i have right now
you may need to ask in a different forum if noone here has any answers for you
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-19-2005, 09:44 PM
that's what I was gonna do but I had at least 5 people tell me (including the two mechanics here) to just add primium gas and let the diesel burn out...
Old 09-19-2005, 09:55 PM
JDPascal JDPascal is offline
Dilution is the solution to this polution of your (lack of) revolution.
You have already diluted it some. Drain atleast 10 gallons out and fill with 10 gallons fresh gas and use regular, it will burn easier.
If it still runs crappy, do it again.
The fuel you remove can be added back in in small amounts (couple of gallons) every time you fill up....
Don't think this would have damaged anything else but give it a try....
JD
Old 09-19-2005, 10:26 PM
ya, I'm gonna try replacing the fuel filter cuz that could be doin it too and it badly needs to be replaced, so if that doesn't work then it looks like I'm siphoning my tank:P thanks guys
if anybody else has more ideas please post! It's much appriciated!
Old 09-20-2005, 09:02 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Change the fuel filter, allow the fuel line to drain AND drain the tank.
Then remove the tank, remove the fuel sender unit, rinse it out with several spray cans of brake cleaner. Make sure it dries with no residue.
Install the tank fill it and drive it until it stops smoking. You may have to get a mechanic to run some proper fuel injector cleaner down it (NOT the cheap stuff you put in the gas tank.
Do not keep or use the diesel contaminated stuff that you drain from the tank.
The key here is diesel leaves parrafin wax deposits that do not wash away readily. This wax gets everywhere and will affect the performance of the injectors.
Finally slap your friend on the head.
