Old 09-19-2005, 09:01 PM
carguyvr4 carguyvr4 is offline
Send a message via AIM to carguyvr4
loud moan/wineing
everytime i hit 3 n ahlf or 4 grand in a gear something seems to wind really loud till then eventually goes away but u can kinda feel some little vibration what could it be any ideas???? something clanks to when the clutch engages in 1st threw 3rd gear ????
Old 09-19-2005, 10:11 PM
powershifty powershifty is offline
Re: loud moan/wineing
If you have your stock blow off valve on, they usually go bad and make a maon/hooting sound. Its your blowoff valve leaking. You definately should get it replaced, your loosing power. Thats just a guess at what your hearing.
Old 09-19-2005, 11:37 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
whining? your intake. get used to it.
clanks? try shifting before 6k rpm.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-20-2005, 09:11 PM
deagle50ae deagle50ae is offline
mine does the same thing. ('93 VR4) sounds like a wookie. it is the BOV leaking and at 3-4k it Resonates loudly. I am saving for a greddy type S. the issue wont cause damage but you are losing a ton of power.
Old 09-23-2005, 12:25 PM
Igovert500's Avatar
blue + red light magnet
Yeah, if it sounds like a hooting owl, wookie, goose, whatever..it's your stock BOV. Get an aftermarket one.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
