Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 09-19-2005, 08:07 PM
Phil_usa Phil_usa is offline
Head Gaskett for small block
I have a 283 I'm putting different heads on. The holes in the head gaskett are very small compared to the water jacket holes in the block. Is this normal? Should I cut out the holes in the gaskett to match the water jackett holes?
Old 09-20-2005, 06:14 PM
mdcamaro mdcamaro is offline
Re: Head Gaskett for small block
Yes do port match the gasket to the head. I put LT1 350 202 heads on a 283 it ran like a dog. I then put on 305 heads it ran great. I would recommend World Products 305 cast iron heads for the street.
Old 09-21-2005, 07:55 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
I wouldn't consider playing with a 283 unless it was left bone stock. You're better off with a 350 in the long run. The 283 had no PCV system on it, oiling is much better on the later 327 and 350 blocks.
Bob
Old 09-22-2005, 06:43 AM
The 283 has a forged steel crank and a 3" stroke. I reved mine to 8 grand no problem. I used Z28 oil pump and pan. I also used a solid lifter 327/365 fuelie cam. The 327/350 HYD cam is also a good choice or any after market cam patterned off of these. 650 Deamon carb and a air gap manifold will give you 300 hp that is street-able.
