Old 09-19-2005, 07:46 PM
preidster preidster is offline
Unhappy 89 RS 2.8L Running great, washed motor now starting problems.
Help!! Just bought a used 89 RS with a 2.8L FI motor. Ran fine, took it to the car wash and srayed the motor to clean it which I have done for years on all my vehicles. Started up ruff, took off and died like you flipped a switch. Got it to start after letting it sit for 2 hours and cranking it on and off for 15 minutes. Took off dies after 300 feet. Let sit untill morning started up after cranking on off for 2-3 minutes and idled like a cold engine should. Touched trottle and it died. Got it to start once more after 5-6 minutes. Reved up to 3-3.5 grand seemd ok took off maybe a 1/8 mile and died like a switch was flipped again.
Had it towed home. Checked distributor for dryness and blew it out and cleaned everything I could get to. Reseated any connectors I could reach, won't start. Any ideas?? Thanks
Old 09-19-2005, 08:21 PM
Matt365's Avatar
Matt365 Matt365 is offline
Send a message via AIM to Matt365
Re: 89 RS 2.8L Running great, washed motor now starting problems.
maybe u fucked an o2 sensor with the water? not sure even if u have an o2 sensor jus heard thats a common problem with engines that have been washed.
Old 09-19-2005, 10:05 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
I'd say you got water in the distributor and uffed it all it up.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 09-19-2005, 11:42 PM
ct91rs ct91rs is offline
Originally Posted by preidster
sprayed the motor to clean it which I have done for years on all my vehicles.
FYI: Cold water on hot engine = very bad things (risk of heads/block cracking or warping). If you want to wash your engine, do it in your driveway after it has cooled down. Cover or carefully avoid getting the distributor wet in the future.
It should run without dying even with the O2 sensor disconnected. You may have cooked the ignition control module.
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson
Old 09-20-2005, 10:14 AM
Re: Re: 89 RS 2.8L Running great, washed motor now starting problems.
Thanks, I used a spark checker and the coil wasn't putting anything out picked up another one at Pick and Pull it started right up. Don't think I'll wash it at the car wash any more.
Old 09-20-2005, 02:39 PM
Re: Re: Re: 89 RS 2.8L Running great, washed motor now starting problems.
Good to hear you got it runnin' again.
