Dalalogging
I have a datalogging cable for my laptop, but all the programs I have for it suck! I can't get them to work with my laptop, it won't read my car right. Do you guys know of any good datalogging programs out there???
![]() 1991 Dodge Stealth R/T NA ATX Dual Exaust w/12" Glass Packs2002 Ford Ranger XLT Ext Cab 3.0 V6 |
Re: Dalalogging
try the Seach function. its quite nice. let me refer you to a thread that's only about 1 month old: http://www.automotiveforums.com/vbul...d.php?t=433120
as to your question, laptops don't really work well (if at all) with datalogging programs, unless your laptop has a serial port, then it might work. you'll most likely have to get a palm pilot or equivalent. off e-bay they are really cheap, about 10-30 bucks. then you need a serial port adapter cable (about $5). the software that works is MMCd datalogger. a list of compatible components (palm pilots, etc) can be found here: http://mmcdlogger.sourceforge.net/ however, the above page does not have the complete datalogging software: there's no executable file (.prc file) in the download. go to this page: http://www.ecimulti.org/mmcd/, and download the 'MMCd Source 1.71.01132005' file. this one has the executable .prc file. the thread linked above is also helpful. good luck.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Re: Dalalogging
Thanks, I searched for datalogging, never thought to search datalogger. I will definitly look for a palm and get that software sounds like the best bet. Thanks for your help man.
