Old 09-19-2005, 04:47 PM
keithmur keithmur is offline
700r4 doesnt have speedo drive
Ok I thought everything that had an r4 in it had a VSS this one has a gear drive. Does any know what year it could be, so that I can find a sensor to drive the speedo? Does anyone make a geardriven signal generator?
Old 09-20-2005, 04:31 PM
CD Smalley CD Smalley is offline
Re: 700r4 doesnt have speedo drive
Well my 89 9c1 has a 700r4 and it's a gear drive. The VSS is located in the speedo itself. Now the 700r4/4l60 sitting on my garage floor, which came out of my 92 Astro, has a VSS.
So where in there...
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 09-22-2005, 04:02 PM
bottomtech bottomtech is offline
you can convert the trans to vss. your would need the reluctor ring and the sensor. Pull the tail shaft off, remove speedo gear and clip, press the reluctor on, install vss in place of driven gear housing.
Old 09-22-2005, 08:48 PM
So then I could convert my vss one back to a gear drive as well with the correct parts?
Is that correct???
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 09-25-2005, 12:37 PM
that is correct, be careful with the gear clip, it's easy to distort
Old 09-25-2005, 12:45 PM
to further clarify,
you would need the correct gears (see bowtie overdrives' website for a gear selection equation), the driven gear housing(two different depending on size of gears), the hold down clip (if different than the VSS one) and the drive gear retaining clip. All the trans I've seen have two clip holes in output shaft under reluctor ring (I believe the front is for the corvette output housing, the rear is for all others. Just slide the drive gear on, temporarily install the housing and make sure the gear is centered in the opening) That way you can be sure you are using the right hole.
