Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 09-19-2005, 01:03 PM
cougar17 cougar17 is offline
Question Braking problem 1999 Cougar
I have recently replaced rotors and pads all around on my 1999 Cougar. I immediately had a problem with a 'soft' brake pedal ( drops about 1/2 way before engaging brakes). I power bled each wheel and replaced the brake fluid entirely in the process. No air was evident. All slides are funtional and there is no indication of any line or caliper leaks. All calipers are funtional. My Chilton manual has a troubleshooting chart suggesting that the rear wheel automatic adjustment (???) may be the problem. The rear pads do not seem to be as tight against the rotor as I would expect (no drag at all). This one has me stumped and I would appreciate any help offered.
Old 09-20-2005, 08:12 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Did you not bleed the brake fluid at the bleeder on top of the transmission?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
