Old 09-19-2005, 10:36 AM
vnotaro vnotaro is offline
ABS Recall
I've just started to experience the ABS activating below 6 mph on my truck ('01 LS 1500 4wd) and was going to get to the front wheel sensors to clean things up. On a whim I called Chevy (800-222-1020) to see if they had initiated a recall for this. (I believe Canadian trucks have been recalled for this). The customer service rep said that GM was still gathering info on what model trucks this was affecting and that a recall notice should be going out sometime in November to the proper owners. She took all my info based on my VIN number and added it to the database (or so she said). Anyone that is having this problem, and I know from this forum alone that there are a bunch, should call Chevy and complain. Have your VIN number ready. Even if you can't wait and have a repair done, keep your receipts. I was told that you can submit a claim for reimbursment if a recall goes out.
Old 09-20-2005, 07:31 AM
beer-b-q's Avatar
beer-b-q beer-b-q is offline
recall
I had a recall on my tailgate cables and you were only reimbursed if a chevy dealer did the work. Just my 2 cents.
Old 09-20-2005, 07:53 AM
mjgjr72 mjgjr72 is offline
Re: recall
if you get a recall for a problem you already had fixed and have the receipt for parts and labor chevy will reiburse you a certain amount for the parts and labor if repaired somewhere other than a gm dealer.
if you bought the cables and have the reciept but replaced them yourself you can submit for a reimbusment for the cost of the cables.
Old 09-21-2005, 06:26 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Re: ABS Recall
I needed a new sensor and Chevy wouldn't sell the sensor without the hub, the turkeys. They wanted $400 for it but I found a dealer in Texas that sold me the hub for $150 and it fixed the problem.
Old 09-21-2005, 10:30 AM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: ABS Recall
I have the ABS problem all the time....Im just hoping i dont hit anyone until the recall...
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 09-21-2005, 08:15 PM
Sonny01's Avatar
Re: ABS Recall
Hey korndog...I have a spare sensor for $50 if you need one and I bought another hub with sensor because I thought the other side would need replacement. I'd sell it for what I paid for it...$150. $5 delivery on the sensor and $15.00 on the hub (it's heavy).
Sonny01
Old 09-21-2005, 10:05 PM
korndogg's Avatar
Re: ABS Recall
im gonna wait till the recall and go from there. Thanks for the offer.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 09-23-2005, 03:24 PM
I read a news release from GM that said that the recall was only going to be in 14 northern states. I can't remember which ones, but I'm pretty sure it's all of New England then the states that border Canada.
Old 09-24-2005, 09:12 AM
tbill tbill is offline
Re: ABS Recall
the dealer i work for has been cleaning the sensors under warranty for about 3 weeks now [NY], we know the recall is coming, just not sure when, we see alot of these things. from what i have heard/read it's gonna be a 'rust belt' type campaign. if you're worried about plowing into something in the meantime, pull the ABS maxi-fuse out of the UBEC [underhood fuse box].
Old 09-24-2005, 05:58 PM
korndogg's Avatar
Re: ABS Recall
well if its not in wisconsin. Thats BS cause we get tons of corrosion around here.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 09-24-2005, 08:36 PM
phlyfshr1 phlyfshr1 is offline
ABS Me too!
Thanks for all the detail on this forum regarding these damned brakes... I luv my chevy but! This 02 is starting to get the best of me/ First it was the near disappearance of the rear brakes and rotors at 20K miles... replaced them an the checked the front pads and rotors to find the outside pad and rotor surface lookd great, "unused" but, the inside pad had worn to the metal plate and trashed the rotor... closer inspection revealed the outside pad had seized... Brakes all the way around...
Another chevy forum that I was monitoring said that other silverado owners were cleaning and checking brake at every tire rot. Gimme a "brake"!
Now I'm Just shy of 40K
Couple weeks ago coming into a slow stop I was faced with thte phantom ABS and found myself pushing the trailer hitch of the truck in front of me into my Lic plate. The guy was very understanding and no damage done... And then it did it again... This time I was ready and no
collision. I spoke to a guy at a local garage and he mentioned the same thing noted in this forum that it's been happening to a lot of Chevy trucks... Suggested pulling the 60A fuse 'til I could get the sensors looked at or replaced or I'd get surprised and really rear end somebody... I just climbed out from under that beast abd there's no apparent window or friction disc to clean. Looks like some sort of magnetic sensor... Guess I'll get on board w/ the NTSB, become a recall statistic with the rest of the Silver owners and try to get in for an ABS repair... Til then the 60A fuse sits in my console...
Thanks again for the info
p.s. I know it's probably under another posting but I had the infamous clunking steering column to... It got greased once and then "finally" replaced with the ec'd version...
Old 09-27-2005, 05:42 PM
Re: ABS Recall
we got the official recall paperwork today, none of the lubricant it calls for, but we got the info today. if i think of it, i'll write down the recall number, and what states it applies to, then post it here tomorrow after work.
Old 09-27-2005, 10:18 PM
korndogg's Avatar
Re: ABS Recall
OH WHAT THE HELL....I just looked at the recall online and its in Illinois and Michigan but not wisconsin. Im calling GM and bitching thats for damn sure.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 09-28-2005, 05:47 AM
jers99z jers99z is offline
Send a message via AIM to jers99z Send a message via MSN to jers99z Send a message via Yahoo to jers99z
Now my truck was originally an Ohio truck, Now that i live in hawaii is there any possibility that the reacall will affect my truck.
99 Z-71 5.3 liter. Jet stage 2, volant cool air intake, flowmaster 40 series, billet grill, clear corners, chrome bed rails, pioneer cd player, Infinity Kappa speakers, silverstars.http://www.cardomain.com/ride/2094079
Old 09-28-2005, 06:30 PM
Re: ABS Recall
ya, i forgot to bring the copy home, but it looks to run from west va to maine, along with michigan and illinois and ohio.
bring it to ohio, and i'm sure it'll get done
