96 Blazer wont crank--Help
My guess is the problem is in the start circuit. But trouble shooting is tough without a factory manual, all I have is a haynes and they su0k. The selonoid doesn't get power in the start position But the truck will crank and start with a 12v jumper to the selonoid. I tried moving the gear selector around but still no crank. The 96 S-10 is the girl friends and I don't know where the neutral safety switch is to check or what else I should check. Any input will help as today was to be a day hanging my new heads on the L98 in my Jag. Update: found a fuse marked crank and the fuse is good but doesn't have power in a crank mode? Also after a search here I think I found the neutral switch on the tranny, plastic gizmo with a couple of plugs on the shifter shaft? What wires come into play? TIA
Re: 96 Blazer wont crank--Help
Did you check the battery voltage?
Did you clean the connections to and from the battery and starter and solenoid?
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: Re: 96 Blazer wont crank--Help
