Code P1400,& P0340
cAN ANYONE PLEASE TELL ME WHAT THESE CODES MEAN?
What should I do to correct this problem? It is a 1996 Ford Tarus. Thanks, Danny |
Re: Code P1400,& P0340
The code P1400 is a Ford Enhanced OBD-II code for "Differential Pressure Feedback Electronic Sensor circuit Low Voltage." There are a lot of posts on this forum related to faulty DPFE sensor failures. Do a quick search for DPFE. Most suggest getting a factory Ford replacement sensor.
The P0340 is a generic OBD-II code for Camshaft Position (CMP) Sensor malfunction/no signal. If this is a legitimate code, your car probably won't start or stay running well at all. -Rod |
Re: Re: Code P1400,& P0340
I do not understand why the car performed fine with the faulty components. It seems odd that the $200 of parts would be on the car unless they were really needed. Perhaps not all cars need the parts, but some do and this ensures that they all work the same. |
Re: Re: Re: Code P1400,& P0340
If I think about it in the next day or two, I'll have to pull the "Description and Operation" section up for my 1998 Taurus SHO and see what it says. I can compare that against the regular 1998 Taurus. -Rod |
According to my service manual, the CMP sensor provides camshaft position information which is used by the powertrain control module (PCM) (12A650) for fuel synchronization.
-Rod |
