Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-19-2005, 05:17 AM
Eclipse420 Eclipse420 is offline
Intake Question
I had a custom intake pipe make for my Eclipse GS to put the filter close to the ground. Should I be worried about water getting in if its raining real hard as long as I dont drive through deep water? I wanted it down where it could get as cool air as possible.
Old 09-19-2005, 08:31 AM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
you should be fine as long as it doesn't rain too much or flood but k&n makes intake covers incase it rains hard
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 09-19-2005, 10:10 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Be very careful. I have the AEM cold air intake, and the filter is literally sitting at the bottom of my bumper. There have been several times where I was afraid of sucking up water, just make sure you stay off the throttle and go very slow. Avoid big water puddles if possible. There is a baypass valve that some people use, but I have heard it reduces hp gains by quite a bit, so I never bothered with it. Just use good judgement, and sit out the storm if possible.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-02-2005, 07:55 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: Intake Question
Definately for dry conditions only. I wouldn't use that in a hard rain.
Old 10-03-2005, 01:24 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Intake Question
why risk it? Get the valve.
now - 2000 civic
soon - 2002 is300
Old 10-05-2005, 01:45 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: Intake Question
what kind of hp gains do you expect from an intake like 2hp maybe 3hp,,,,,and i dont think there is much difference between the cai or a short ram,maybe half a horse.
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 10-06-2005, 11:04 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Re: Re: Intake Question
I agree.....^^^ Besides its a metal pipe the air is going to get hotter any way no point on risking your engine for the 1hp that you won't even notice
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
