Old 09-19-2005, 04:05 AM
emil13si's Avatar
emil13si emil13si is offline
CTK: new engine pics
Finally got what I really needed and wanted for a long time Bisimoto engenering header...I mjust say that my rpm limit must go up (right now on 9k rpm) ...engine is pulling amaizinglly strong after 7k rpm to rpm limit
Here it is !
[/i]
CYA
Powered by
CivicTypeKoshiR
Old 09-19-2005, 08:22 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
looking good emil!!!
im really liking what you have done to your car, good work !!! any power figures yet ??
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 09-19-2005, 08:50 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
Re: CTK: new engine pics
why so bendy? whats wrong with the straight down design?
The Evil Sleeper
Old 09-19-2005, 09:33 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: Re: CTK: new engine pics
They are equal length pipes, keeps the exhaust flow tuned properly (so that the exhaust released from each cylinder are kept in order and not bunched up where they will restrict each others flow through the downpipe/collector/cat/exhaust... Don't know if that makes sense, but if each exhaust burst has to travel different distances (like on normal headers), then when they go into the downpipe, some of them get bunched up (one travelling a longer distance might come into the downpipe at the same time as one that travels a shorter distance)....
Old 09-19-2005, 09:34 AM
emil13si's Avatar
This is how you get long primary pipes and don't need to have your 4-1 tube under the oil pan...
Car is so low that when I wanted to put on jun 4-1 header the header was about 3cm of the ground...I sold that one not even takin on the test ride cause I wouldn't get out of the garage...
With this one you don't need to change front cross memeber and the 4-1 goes right in the midlle of the engine so where the oil pan is there is just one tube-pipe 2.5" no way you can hit those on road bumps !
And the other reason is that Bisi made it I always want his header...
http://www.bisimoto.com/
About the HP I don't know how many "hamsters" are runing in the engine right now but before I add
-TB STR 68mm
-ENDYN NA High compresion pistons
-Bisi header
-2.5" SS light weight exhaust
-custom CF intake
it had 193HP...
I need more money to buy BCIV cams and new valve train (right now it has ITR one)
CYA
Powered by
CivicTypeKoshiR
Old 09-19-2005, 09:38 AM
emil13si's Avatar
And like ci5ic said those are equal lenght pipes !
Powered by
CivicTypeKoshiR
Old 09-19-2005, 10:19 AM
clawhammer's Avatar
clawhammer clawhammer is offline
Which engine is that?
2001 Honda S2000 New Formula Red
Mods:
Engine: Comptech Air Intake Box, miscellanous chrome dress up pieces
Suspension: Comptech front strut tower bar
Exterior: Grillcraft grill, lots of wax
Interior: Rick's leather console cover, Muz one-piece luxury floormats, Rick's windscreen,
Electronics/Audio: Polk speakers
Wheels/tires: 18" SSR Competition wheels with 225/40 and 255/35 tires
Old 09-19-2005, 10:35 AM
91CRXTC's Avatar
i understand the equal legnth pipes, but they couldnt get equals without all thoughs bends? I have a "HP Racing" header on my ZC, it was bought for an SI but is matches up with the ZC, i have a slight spurattic bog and am wondering if its because my pipes are not equal legnths. Its got the same layout style as the DC header with that one pipe from cyl 4 that goes around the back of the other 3 pipes and the O2 sensor on one of the pipes. I am thinking that that 1 pipe is longer then the rest and is causing a slight spuratic bog. So the 4-1 setup is for 1/4s and a 4-2-1 would be better for track use? So who makes a good 4-2-1 equal legnth pipe header for the ZC?
The Evil Sleeper
Old 09-19-2005, 07:08 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Damn, thats really coming along great emil! i love when n/a's can whoop on f/i .....much respect!
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 09-20-2005, 02:08 AM
emil13si's Avatar
@91CRXTC: best headers on the market, they are all equal lenght, bisimoto, hytech, an-r ... but they are all pretty expencive...not cheap stuff !
CYA
Powered by
CivicTypeKoshiR
Old 09-20-2005, 02:15 AM
emil13si's Avatar
I'm tryin' to keep up in the NA scene but it's so damn expencive,
lots of parts bought and I must buy a lot more, so 2-3k $ additionally will be invested in the engine so it'll run it's top power...
Parts that I would like to put in:
-BC IV cams
-BC cam gears or toda racing
-Skunk2 or Toda racing valve train
-msd ignition or naything else that would be better thean stock, cause I really heat that orig. ignition always giving me troubles
-custom made ITBs
-maybe new final drive in gear box
That would really help improve my 1/4mile time...
Before I add Bisi best ET was 13.7s so now I'm goin on low 13s with bisi on and new optimizacion of ECU
CYA
Powered by
CivicTypeKoshiR
