Old 09-18-2005, 11:14 PM
kalam2b kalam2b is offline
Need help on styrene sheet size.
Hi,
Since it's hard to find styrene sheet in Malaysia, i'm going to order it through internet, so can u guys suggest which size should i buy (frequently use size). Before this i've used plastic card from ice-cream container and it's hard to form it to certain shape.
Old 09-19-2005, 02:52 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: Need help on styrene sheet size.
The size isn't really important unless you make a really large part that requires a large area. Most of the US products are 6 x 12 in, while Tamiya makes some in the Japanese B4 format (257 x 364 mm). I assume you're ordering more than one item to save per-item shipping cost, so I suggest you get several kinds of thickness like 0.2 mm, 0.3 mm, 0.5 mm and 1.0 mm, the thickness I consider super-thin, thin, medium and thick in 1/24 scale modeling.
Hiroaki Fukuda
Old 09-19-2005, 07:16 AM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
I agree: Order a selection of of sheets in different thickness, so you'll be able to use one to match that application.
Styrene rod, round and square, is pretty cheap, so you might want to pick up some of that too. The round rod sizes most commonly used are 1mm, 1.5mm, 2mm, and sometimes slightly larger.
