Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '88 - '92
Old 09-18-2005, 10:47 PM
red_bull red_bull is offline
92 passat wont start
my 92 passat is having some issues, i just put in a new starter however, the car now cranks but wont turn over, what should i check for on the fuel injectors? could it be the fuel pump? something else? should i just get a mechanic with a diagnostic?
Old 09-19-2005, 05:57 PM
boschmann boschmann is offline
Re: 92 passat wont start
Do you get a spark from the coil wire?
Old 09-19-2005, 08:53 PM
Talking Re: Re: 92 passat wont start
This would be determined by...?
Old 09-22-2005, 07:59 PM
Removing the coil wire from center of distributor cap & placing near a ground. Then crank the engine and look for a spark jumping to ground.
Old 09-25-2005, 08:42 PM
Yes there is a spark, also when u pump the gas while cranking the car, it begins to turn over, but doesnt, a friend of mine having a similar problem with a porshe was told to change his fuel pressure regulator (very expensive).
Old 09-27-2005, 08:52 AM
After cranking for a minute pull a spark plug & see if it is wet with gas or dry. Can you hear the fuel pump running when you first turn the key to the run position?
Old 09-27-2005, 03:34 PM
yes i hear a whiring sound when i turn on the car, if its a fuel pump, i dont know, but i would imagine so, also, the plug is completely dry, but it smells of gasoline, but yes its dry
Old 10-08-2005, 03:33 PM
Dry after craning is actually better. Try spraying some starting fluid into the air intake while cranking to see if it runs for a few seconds.
Old 10-10-2005, 02:42 PM
ok, i sprayed it in the font hole of the air filter box, n no dice, nothing ounded different, also i foun out there is fuel in my fuel rail, so that means its not a fuel pump right, and finally, were is the air filter on my car because when i opened the box there was nothing there could that be a problem, also i have a friend that says he can rebuild my fuel pressure regulator would u recommend this? I appreciate all ur help ur like the king of german cars i have so many mechanic friends and their all baffled because i have a volkswagen
Old 10-22-2005, 12:24 PM
There should be an air filter in the air box. Spaying ether into the manifold should cause the engine to run for a moment, otherwise suspect a cap/rotor/plug wire issue. Make sure the spark is getting to the plugs. I'd think timing belt, but you wouldn't get spark if it broke, perhaps it jumped a few teeth. You need to check the marks on the flywheel & cam sprocket.
