Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-18-2005, 10:43 PM
IceIceBaby IceIceBaby is offline
89 GT Loses power when key is turned
I have an 89 convertable and when I turn my key to accessory the lights go dim. When I try to turn it more to start it, everything gets even dimmer and my alarm goes off and the car won't start. I'm thinking some sort of short maybe ignition????. I've checked fuses can't find any loose or corroded wires.... help please.
'89MustangGTConvertible
324rwhp 411rwtq
1/4:73.55secs
Old 09-25-2005, 01:32 AM
Demonhunter Demonhunter is offline
Re: 89 GT Loses power when key is turned
errr ummm...im sure you checked the battery. Check the terminlas for corrosion and even if none is visible clean the posts and connectors down to shiney some shiney lead. Sometimes it the most simple things...hope this works for ya!
Old 07-29-2006, 11:20 PM
N2TRUKN N2TRUKN is offline
I Have To Agree With The Other Guy. But Wanted Add That The Conection From The Wire Its Self To The Part That Clamps Oto The Post. Plus If You Have Amps And Stuff, After Market Radios, Extra Lights, So On Turn That Stuff Off And Try It. Good Luck.
