My alldatadiy is only good for 2000. So I needed to goto the
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm and do the search. I would contact GM about the VIN and see if the work was done. Also note: only the original owner is usually notified of recalls, I bought my car from a GM dealer used and have never been notified of any recalls.
Make : OLDSMOBILE
Model : INTRIGUEYear : 1998Manufacturer : GENERAL MOTORS CORP. NHTSA CAMPAIGN ID Number : 03V527000 Mfg's Report Date : DEC 11, 2003Component: STEERING:RACK AND PINIONPotential Number Of Units Affected : 750283Summary:
CERTAIN PASSENGER VEHICLES HAVE LOWER PINION BEARINGS IN THE POWER RACK AND PINION ASSEMBLY IN WHICH THE RETAINER TABS WERE NOT CRIMPED PROPERLY. THESE RETAINERS COULD FAIL AND PERMIT THE BALL BEARINGS TO ESCAPE. Consequence:
IF THIS OCCURS, THE PINION SHAFT CAN BE FORCED UPWARD DURING LEFT TURNS AND BACK DOWN AS THE STEERING WHEEL IS MOVED BACK AND TO THE RIGHT. IF THE PINION SHAFT MOVES FURTHER, THE DRIVER WILL NEED TO EXERT MORE EFFORT TO TURN THE STEERING WHEEL, SIMILAR TO A VEHICLE WITHOUT POWER ASSISTED STEERING. IF THE PINION SHAFT MOVES EVEN FURTHER, THE DRIVER WILL REQUIRE MUCH HIGHER EFFORT TO TURN LEFT AND MAY NOT BE ABLE TO TURN THE WHEEL AS MUCH AS INTENDED. WITH THE MAXIMUM PINION SHAFT MOVEMENT, WHICH REQUIRES INTERNAL GEAR COMPONENT DAMAGE, THE DRIVER CAN ENCOUNTER HIGH RESISTANCE TO TURNING LEFT, FOLLOWED BY UNINTENDED POWER ASSIST TO THE RIGHT. IN ANY OF THESE CONDITIONS, A CRASH COULD OCCUR. Remedy:
DEALERS WILL INSTALL A NEW LOWER PINION BEARING UNLESS INSPECT OF THE EXISTING BEARING INDICATES THAT REPLACEMENT OF THE GEAR ASSEMBLY IS NECESSARY. OWNER NOTIFICATION BEGAN ON FEBRUARY 5, 2004. OWNERS SHOULD CONTACT BUICK AT 1-866-608-8080; CHEVROLET AT 1-800-630-2438; OLDSMOBILE AT 1-800-630-6537; OR PONTIAC AT 1-800-620-7668. Notes:
GM RECALL NO. 03062. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
