Old 09-18-2005, 06:15 PM
ice91785 ice91785 is offline
Thumbs down 92 Caravan Start Question
My 92 Dodge Caravan (v6). Is having some problems starting up. It cranks over just fine and fires up for only a second and then quits. This happens constantly and will fire everytime, but will also die everytime. I just put in a new fuel pump/filters....Fuel pump, fuel pressure (80 lbs), fuel regulator were all ok....
I ran a diagnostic and it came up with a code 55, but the manual said it "was not available." Can any of you guys help me out? Thanks
Old 09-18-2005, 08:21 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
Re: 92 Caravan Start Question
55 means end of codes
does it die once you release the key? or a while after?
Old 09-19-2005, 07:38 AM
It fires, so I release the key. It runs for literally 1-3 seconds and just quits. But like I said it will fire EVERYTIME, just quits right away. The ONLY code I got was a 55, and like i said I checked all the other fuel system stuff. I just dont know...
Old 09-19-2005, 08:48 AM
Rottweiler28's Avatar
Rottweiler28 Rottweiler28 is offline
How was it running prior to this problem starting? Could be possible very dirty injectors. Not sure if a crank sensor would do this, I would think it wouldn't start at all if that was it. You could try pouring some gas directly into the intake and see if it runs any longer that way, if so possible FI's.
Old 09-19-2005, 08:40 PM
Re: Re: 92 Caravan Start Question
I tried the idea pouring gas directly into the intake already but it made no difference.... any more ideas???
Old 09-19-2005, 10:43 PM
Re: Re: Re: 92 Caravan Start Question
Well my next step would be checking spark, pull a plug wire off and stick another (extra ) plug in it (or just pull plug and all) and ground it to the plenum while you have someone crank the engine, see if you get spark the whole time it is being cranked over, if not then it is an eletrical issue.
Old 09-20-2005, 02:23 PM
lezco266 lezco266 is offline
Hi
I had a similar problem and it was the battery not providing enough voltage, I litterally had to floor the throttle to keep the engine running . Otherwise your alternator has failed
