Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 09-18-2005, 03:17 PM
RESTREC RESTREC is offline
Starting without starter.
I friend called me yesterday from a town 2 hours away and described me all the symtoms of a starter that would not work any more in his 93 Aerostar. I instructed him thru the phone to perform all the tests known just to get the engine running once more to avoid paying a tow truck. Nothing worked. He was towed. The question is: can a car with automatic transmission be pushed while in a gear to start the engine as it is a done with a manual transmision one ? Thanks.
Old 09-18-2005, 08:05 PM
mastermech mastermech is offline
no you can't push start an automatic trans because there is no clutch to "connect" the engine to the driveline. An automatic works by pressure flowing thru the torque converter and thru the tranny.
Old 09-24-2005, 11:57 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Starting without starter.
Back in the late 40's to the early 1960's, some auto transmissions had a rear fluid pump, as well as a front pump. The rear pump was specifically designed to rotate with the driveshaft and pressurize the transmission hydraulic system, allowing a push start.
However, with the advent of reliable 12 volt starting systems, such transmission designs were dropped simply because they were needed so rarely.
Old 12-19-2005, 12:13 AM
Ima Ludite Ima Ludite is offline
Re: Re: Starting without starter.
That is a common problem. Your tow truck drive should have known to rapp the starter with a wrench/hammer and it will then start for a few more times.
Old 01-31-2006, 09:17 PM
occupant occupant is offline
Send a message via ICQ to occupant Send a message via AIM to occupant Send a message via Yahoo to occupant
Powerglides can be push started, as well as very old Torqueflites. Maybe Ford-O-Matics (the 2-speed kind). But to start an Aerostar with a starting issue, I always try to crank it at the solenoid. It's how I've started mine for over a year because I'm too lazy to replace the ignition switch.
Old 01-31-2006, 09:32 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
10-4 on the old hammer rap start.
It is sometimes good for another start or two.
But tow trucks drivers usually do not tell you how to get it started untill after they get the tow.
MT
