Old 09-18-2005, 02:38 PM
ReCKleZ ReCKleZ is offline
Head Light Problem
Hello guys, I have a 2002 Pontiac Firebird and something weird started happening yesterday. Everytime I unlock the door or lock it and close the door the headlights open for about 2 seconds then close and once they are closed the left headlight starts making a noise like its having a hard time closing for like 5 seconds. Like the motor is still trying to close it. Any ideas on what this could be and how I could fix this?
Thanks,
Frank
Old 09-18-2005, 02:57 PM
Matt365's Avatar
Matt365 Matt365 is offline
Send a message via AIM to Matt365
Re: Head Light Problem
sounds like a wiring problem.
Old 09-18-2005, 03:32 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
More like the gear in your headlight motor is stripped.
http://www.bfranker.badz28.com/headlightfix/
Not too sure about what's up with the locks and closing the door making the lights come up. I'd take it in to get looked at if it still keeps doing it after you fix the headlight motor.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 09-18-2005, 04:53 PM
wilson05's Avatar
wilson05 wilson05 is offline
Send a message via ICQ to wilson05
ok for one thing thats crazy about the door locks and headlight motors running at the same time haha mabye a ghost??? no probably not but anyway sounds like a bad relay ? i'm not sure but i dont think that the doorlocks and the headlight motors are even on the same fuse ... i'd have the wiring checked and if no simple solution is found then you could always run a switch to the headlight motor and the battery and eliminate the one that activates when the lights are turned on
Old 09-18-2005, 09:12 PM
95redTA 95redTA is offline
Headlight Motor Gear
It is actually your headlight motor gear that has gone bad some how its all wired together and since the gear is stripped the car doesn't think the headlights are all the way down when they are supposed to be and it confuses the computer. Just go to the link posted above and buy a brass replacement gear, its a fairly simple install a child could do it.
Old 09-18-2005, 09:16 PM
forgot to say you can also find the brass gears on ebay by searching "firebird head light motor" and that the head light messing up with the door locks and stuff being a fairly comon problem
Old 09-19-2005, 01:04 PM
FormulaRX7's Avatar
FormulaRX7 FormulaRX7 is offline
Send a message via AIM to FormulaRX7 Send a message via MSN to FormulaRX7
Wow, i just had this problem not 2 weeks ago with my 98 formula. What had happened is that the left motor was bad and i had to replace it. I paid roughly 400 for a new motor and all so it was kind of steep but you can find another motor for the headlight off ebay. Not the most glamorous approach but its a quick fix none-the-less... also, i find the irony in this thread because after i solve my problem someone else posts about the same thing... oh well... such is life. :P
When your the only one on the road, that's all that matters...
Old 09-27-2005, 08:51 AM
Thanks fellas!
Hey guys, I just wanted to thank everybody for all the help. I will try to fix it myself following the instructions on that site and see what happens and post a reply when I get it to work. This forum rocks.
Sorry about that FormulaRX7.
Thanks to everybody,
Frank
