need to run a power wire for an amp through fire wall
I'm looking for the best way to run a power wire for an amp through the firewall. If anybody has done this in the past and has any suggestions, i'd sure appreciate it.
Re: need to run a power wire for an amp through fire wall
I personally prefer the throttle cable boot 'cause every one I've had to deal with was rediculously oversized and easy to get to. Just make sure your installation won't interfere with normal operations, or come anywhere near metal surfaces that can cut or rub through your new cable's insulation. Fuse the battery end just to be safe.
-Steven 1996 Town Car, Cartier |
i took and ran my 4 gauge amp wire through an existing weather boot on the pssenger side fire wall just drilled theough it and ran the wire through clean and easy install
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs ![]() also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon |
Personally, I like to keep the trim removal down to a minimum. On my 88 Town Car I ran an amp power cable along the frame inside some weather proof conduit, and then up through a rubber boot right behind the back seat and then into the trunk. It saves a lot of time if it's possible for you to do on your model.
Re: Re: need to run a power wire for an amp through fire wall
