I need help. My car has a problem of not staying fired. When I try to start it, the engine will fire like its suppose to but after I turn the key back the engine dies. I have spark and fuel but it seems that its not holding it. It will start intermitly. Like it will start sometimes. And when i had the key turned all the way and held it, it seemed that was helping keep it fired. Please help i don't know what's wrong with my car.
Re: It wont stay fired!
did you adjust your idle or something...did you try holding the gas a little after you let off the key to see if it was idling to low?
the main relay might be bad...? dose it start every time?
_________________________________http://VelocityFactor.com________________________________ 1990 si hatch b20b si tranny megan race header 2.5 custom exhaust 50 shot integra da rear disk (w/ 4040 valve) powerslot rotors and barded lines all around 1994 Dx hatch stock |
Re: Re: It wont stay fired!
yes i tried to keep it running by fluttering the gas pedal but it would not stay running. though sometimes you start it and it stays running?? |
Re: Re: Re: It wont stay fired!
Honda Enthusiast
it definitly is your ignition switch. 100%
thanks...i'll give that try and let ya know.
on the ignition switch there is off, acc, on, start. in the on position, that's when u'r dash lights come on and the fuel pump primes and u'll here the main relay click. if u r getting all those in the on position, then it's not the ignition switch causing the problem. if u'r not getting them then that's it.
