Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 09-18-2005, 01:01 PM
DALEXANDER DALEXANDER is offline
Send a message via AIM to DALEXANDER Send a message via Yahoo to DALEXANDER
check engine light
Today is 9/18/05. I took my dodge stratus coupe 2001 to the dealership 7/8/05, because the check engine light came on.
But 4 days later it came on again and stayed on for 2 days.
It was off again for 7 days.
Then on again for 2. Off again for 10 days then back on for 2.
My driving was never any different, why would the light come on then go off like this? No problems with the car, gas cap closed.
If they performed a service and then the light still comes back on, did they forget something? Can they be held to "complete" the job? Or does this happen a lot and things just slip by the machanics?
Old 09-20-2005, 12:54 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: check engine light
try going to your local auto part store, like Autozone or Napa, and ask them to pull up the check engine light code. From what it appears is that you have an intermittent fault in your system. With 2001-newer vehicles, they are very sensitive and will set a code for things as small as the fuel level sensor not sending a certain voltage.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 10-13-2006, 09:37 PM
jcmevakg jcmevakg is offline
i have the same problem with mine. it could be the egr sensor. emissions gas regulator
Old 02-02-2009, 05:15 PM
M&Ms M&Ms is offline
I have an 04 Dodge Stratus. I changed the oil with the right weight oil and the filter. The oil light came on kinda slowley and then was bright. We checked the oil light sending unit that was leaking! replaced it cleaned up the mess and again 1 day laiter the light is on. The motor is the 2.7. Anyone else help! Also the next morning was off and when warm was on. I only have 87k.
