Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-18-2005, 01:51 PM
Cobra_Sam Cobra_Sam is offline
Unhappy Plymouth Laser Turbo, will not start
I have a 2L 16 valve Laser Turbo. I changed all the belts and idlers including the timing belt. Put it all back together and she ran like a top for about 5000 miles. I went to a friends house and visited for about half an hour. When I came back out and got in she wouldn't start, engine seems to turn over real slow. It has a new battery in plus I hooked up my other car to it and she still turned over real heavy. I thought that it may be the starter dragging so we towed her to see if she would start ... yes it is a stick shift. Pulled her along and put on the ignition, slipped her into second and let out the clutch .... nothing. Engine just turnes at it own pace. I pulled the oil pan off and noticed that I can turn the rear balance shaft with my fingers from the bottom ???
I know the front balance shaft has a pully and belt that goes around the crank .. anyone know what the deal is about the rear one ?
I have a Haynes repair manual that tell me nothing about the rear one.
Any help will be appreciated .... thanks
Sam
Old 11-29-2005, 09:54 PM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
I have the same problem with the balance shaft on my 92 eclipse turbo...if you find out let me know. My Chilton book doesn't really help with the balance shaft at all, let alone the rear of it.
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
