Old 09-18-2005, 12:43 PM
kernalklink kernalklink is offline
another Trac Off issue
I have just finished my tune up, plugs, wires, fuel filter and oil. about 10 miles after i finished the trac off light came on and the car is shifting very hard the wheels are almost spinning on loose surfaces when shifting. could this just be a bad wheel sensor? The service engine soon light came on about 3 miles after the trac off and no adverse affects could this be related to the trac off? it's my girlfriends car and she is blaming me for this but i cant see any way that i coudl have caused this prblem... unless it's just a loose sensor...right?
Old 09-18-2005, 01:00 PM
so i checked all of the connection at each wheel, all good. unless the sensors are bad that shouldnt be the issue...right? I really hope someone has an idea of why the car would be doing this.
Old 09-18-2005, 03:28 PM
vamc's Avatar
vamc vamc is offline
Re: another Trac Off issue
It could be a senser. you could get a code scanner to tell you whats wrong with it. just a thought.
Old 09-18-2005, 04:34 PM
I am not in the business of "code scanners" what kind would i need, where can i get one and about what would be the cost?
Old 09-19-2005, 02:39 PM
my air intake sensor was unplugged, and that was all... i plugged it back in and it was fine.
Old 09-21-2005, 11:13 AM
vamc's Avatar
get one from autozone.
Old 09-21-2005, 11:48 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
The IAT sensor is an input to the PCM and is one of the sensors the PCM uses for Transmission control.
On some vehicles, if the IAT is left disconnected, the PCM will disable Traction Control (reason the Trac light came on) and set a DTC.
When the DTC is set, the PCM will command full line pressure to the trans (reason the trans shifted hard) to prevent internal failure of the transmission.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
