Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 09-18-2005, 12:16 PM
dragitvinn dragitvinn is offline
1988 Ford Econoline Van Stall When Cold
I Have A Ford Econoline Van With A 5.0 V8. When Its Cold And I Start The Van It Idles Rough And Stalls. When I Drive It Its Fine Till I Come To A Stop Or Revese And Come To A Stop( It Stalls).. When It Warms Up Its Fine .. I CHANGED THE PLUGS WIRES AND CAP AND ROTOR.. I ALSO CHANGED THE IDLE CONTROL VALVE.
Old 09-21-2005, 08:13 PM
mrfixit64857's Avatar
mrfixit64857 mrfixit64857 is offline
Re: 1988 Ford Econoline Van Stall When Cold
Sounds like its getting a bad sensor signal, most likely from the 02 sensor. Theyre about 45 dollars and not too hard to replace, but it will take a bit of driving after replacing it for it to get back to running better.
In short, these sensors work by a kind of thermo-chemical reaction, creating a microvoltage sent to the computer. the tipoff was that it works fine when warmed up, in that if your O2 sensor has failed, it's not making the necessary adjustments to your fuel/air mix via the computer, and hence the trouble.
Good luck
What is life, if not to be laughed at... or caught in a Ford?
have mercy on me...I gave Oil today!
Old 06-17-2009, 08:05 AM
marcuscondor marcuscondor is offline
Hi Guys ,
I have a travelcraft motorhome ( RV to you ) which is based on a 1988 ford econoline 6.8 litre diesel . I live in Britain where econoline knowledge is pretty thin on the ground .
The RV has this cold starting problem where it revs up uncontrolably and stalls about six seconds after starting . If it has been driven in the last six or so hours its OK .
Do i need one of these O2 sensors ?
Regards
Marcus
Old 06-17-2009, 09:23 AM
G0ldRush's Avatar
G0ldRush G0ldRush is offline
I had the same problem and mine was inside the throttle body just beside the papillon those rectangular tiny holes were stuck with carbon check this
If they don't have it, I don't need It!
