Old 09-18-2005, 10:55 AM
ballen2104 ballen2104 is offline
brake shudder
I have a 95 Lumina. I replaced the discs and pads about 4 months ago. Recently it has started shuddering when braking and continues to get worse. It is much more noticable when coming down from higher raters of speed. Where should I go first?
Old 09-18-2005, 11:55 AM
maxwedge maxwedge is offline
A990 racer
Re: brake shudder
Make sure it is not the rear brake drums, with caution, use only the emergency brake to slow down, see if it shudders, it would be the rear. Cheap rotors or failure to clean the rotor mounting hubs, or uneven wheel stud torques could warp the front.
Old 09-18-2005, 11:33 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: brake shudder
does your steering wheel shimmy when you brake? If so, its the front rotors. however, if not, it doesnt rule out the front, if that makes sence.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
