Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 09-18-2005, 10:31 AM
trixx1967 trixx1967 is offline
Send a message via AIM to trixx1967 Send a message via Yahoo to trixx1967
timing belt 2000 kia sephia
could someone please give me step by step instruction on how to change broken timing belt on 1.8 dohc motor...I know that you should change the water pump but am clueless on timing belt...it is a 2000 kia sephia Thank you
Old 10-06-2005, 11:53 PM
cbeck cbeck is offline
Re: timing belt 2000 kia sephia
I think that has been done on this board for the sephia or the riio... It's late now so I'm not going to look. but if you don't find i will look or post for you later... good luck.
edit:oh, nevermind, this was posted nearly a month ago. where have i been?
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor.
Old 07-16-2007, 04:46 PM
kaeru kaeru is offline
there is no timing belt in the 2000 kia sephia. it's got a DIS, it doesn't need one.
Old 07-27-2007, 04:25 PM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
There is a timing belt for the 2000 sephia. It is recommended to be changed every 60k miles. You do not have to replace the water pump unless you are feeling ambitious and or it is leaking. DIS is distributorless ignition system.
Old 09-23-2007, 07:59 PM
ribsbear ribsbear is offline
my son just changed the timing belt 2000 kia sephia, car will not start, he says that it is lined up correct. what is the problem, why the car want start
