Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-18-2005, 10:07 AM
customtoyz customtoyz is offline
Question looking for knowledge on a 1.9l sc1
I have a 96 SC1 with oil mixing into the antifreeze.
My question is where is it coming from the head or the block?
The head was already removed and it was not warped and I did not see any visible cracks, but I did not have it checked by a machine shop yet.
I guess the knowledge I am looking for could it be cracked internally in the head, or in the block.
If in the head is it repairable?
So I can make a decision to replace the head or get it repair.
Thanks for any info,
Customtoyz
Old 09-18-2005, 10:48 AM
bigron bigron is offline
Let me guess coolant looks like choc. milk. The cracks are very hard to find but it is a cracked head. Common enough problem were I'am confident in saying it is the head (save the money on the machine shop and get a head). Some are going to tell you you should replace all the rubber hoses and everything else. the life of these compents has been reduced slightky but as long as you flush the system (until you get clean water comming out you should be fine
Old 09-18-2005, 11:05 AM
Re: looking for knowledge on a 1.9l sc1
Thank you very much for the info.
On the flushing of the system, i purchased a 3 quart bottle of greased lightning poured half of it and mixed it with water and removed the thermostat. flushed it twice with G.L. than flushed it with regular water until all clear. it did a awesome job getting all the goop out.
Second question is there an aftermarket version of the head, or is there a newer year that will bolt-on that might have a better chance of not cracking.
What is the going price for a replacement head?
Old 09-18-2005, 11:34 AM
dont know about aftermarket but they are not extremly expensive from saturn. 3-5 range not 100% sure what customer cost is
Old 09-18-2005, 03:27 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
SPSwebpage.com sells a few performance heads but they are still the OEM casting. any 96-mid99 should fit, i don't know about mid99+.
also you should check your bearings and oil pump.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 10-13-2005, 12:22 AM
billyturbonitrosl2 billyturbonitrosl2 is offline
sounds like it could be a head gasket or cracked head i have 2 dohc and 1 sohc heads for sale
